Hello Guest it is October 20, 2026, 09:46:27 PM
Author Topic: Hi Newbie question  (Read 9645 times)
Hi Newbie question
« on: October 30, 2015, 05:02:21 AM »
Hi
I am Gary from the Uk i was a Firefighter but i have just been forced to retire after 23 years due to ill health.
I am brand new to Cnc but love it so far.
Please forgive me if my question is very basic but up to now i am still pretty unconfident in using more settings in Mach 3 than i need to.
My question is in When using mach 3 is there a way that i can pause my job during the cutting process shut down Mach 3 and my pc restart the following day and carry on my cnc cutting from the point i stopped it ?
For expample if i was going to cut a job that takes many hours to finish i may need to do this.
Thank you in advance and please forgive me if i have posted in the wrong section ect as i have only just registered with this forum.
Offline bfgstew
  •  91 91
  • DOH!!!!!!!
Re: Hi Newbie question
« Reply #1 on: October 30, 2015, 11:33:30 AM »
From my limited experience Gary, I would avoid this at all costs until you get more experienced. Starting back up from where you left off would inevitably end up with a broken end mill, or worse...................Plan the work in advance, I think you can run simulation which will give you duration of process, work from that.
Hope that helps Gary?
Stewart
« Reply #2 on: October 30, 2015, 12:21:45 PM »
Been using Mach3 for about 8 years now.
I'd avoid this as well. Unless your home switches are absolutely spot on you will almost certainly shift a little on re-homing and turn out a bad job, or at worst you could end up with a busted tool, or a damaged machine.
I concur with bfgstew, plan your day to allow complete cycles.
That said, welcome, and enjoy :)
« Reply #3 on: October 30, 2015, 12:57:29 PM »
Thank you bfgstew and thank you bluepinnacle for your advice now i know thats it would be a risky and unpracticle think to do i will definately avoid that scenrio alltogether and if i do have toolpaths to cut which are many hours long i will work it so that i start the cutting first thing on a morning ... Much appreciated ....
Offline bfgstew
  •  91 91
  • DOH!!!!!!!
« Reply #4 on: October 30, 2015, 02:53:16 PM »
No worries Gary, enjoy your new hobby.
And welcome to the forum, ask away if you have a question, be patient for a reply.
