Hello Guest it is October 21, 2026, 10:54:57 AM
Author Topic: Calibration/Steps per unit sanity check  (Read 19150 times)
Re: Calibration/Steps per unit sanity check
« Reply #10 on: November 02, 2015, 02:24:44 PM »
If you just did as instructed the steps per would have been set correctly.
That said calculated based on correct inputs should be darn close to calibrated.
« Reply #11 on: November 02, 2015, 07:17:37 PM »
I did and once using the correct info it works perfectly!
Thanks for your time Rich and everyone.
Also, I used your xls sheet to double check my calcs (Rich). Thanks again!
