Hello
Guest
it is
October 21, 2026, 10:55:11 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Calibration/Steps per unit sanity check
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Calibration/Steps per unit sanity check (Read 19151 times)
Re: Calibration/Steps per unit sanity check
Reply #10 on:
November 02, 2015, 02:24:44 PM »
If you just did as instructed the steps per would have been set correctly.
That said calculated based on correct inputs should be darn close to calibrated.
Logged
iphillips
24
Reply #11 on:
November 02, 2015, 07:17:37 PM »
I did and once using the correct info it works perfectly!
Thanks for your time Rich and everyone.
Also, I used your xls sheet to double check my calcs (Rich). Thanks again!
Logged
Print
Pages:
1
2
Go Up
« previous
next »
