Hello Guest it is October 20, 2026, 03:08:48 PM
Author Topic: Mach 3 utter bollox  (Read 11697 times)
Mach 3 utter bollox
« on: October 18, 2015, 09:23:47 AM »
a couple of questions.
1, why cant I use MDI after running a program? I have to shut Mach 3 down and restart it.
2, why when I use single block on a program (1st run, checking moves are correct) the poxy system doubles up a value and shoots of in whatever direction of the addition
3, there must be better alternatives out there, anyone got a recommendation? ive had enough of this product!
Re: Mach 3 utter bollox
« Reply #1 on: October 18, 2015, 10:26:19 AM »
The expeience of so many others differs from yours that one must suspect something wrong with your setup.
1. Works fine here
2. Dunno, I don't do that as I've found that my machine does exactly as in my CAD/CAM's simulation so I know moves will be correct.
3. Learn how to configure & use the Linux based CNC software, can't help there as Mach3 works perfectly for me.
Are you running an evaluation or licensed product downloaded from the official site?
If you are then there's something at your end that's different than mine as it works and runs fine here ;-)
Best Regards,
Nick
Offline TPS
  •  2,627 2,627
« Reply #2 on: October 18, 2015, 10:29:00 AM »
3, ... ive had enough of this product!
so why should somebody give answers for 1. and 2.
regards Thomas
« Reply #3 on: October 18, 2015, 10:42:08 AM »
He was online when I replied and obviously went elsewhere when a sensible reply was forthcoming, perhaps he's looking at the Linux forum?
Nick
  •  9,374 9,374
« Reply #4 on: October 18, 2015, 11:00:36 AM »
Hi Wayne,
I am truly sorry that you are having problems but I suspect you need to spend more time reading the manuals, watching the video's and checking your setup, PC settings, etc. in order to get Mach3 working correctly with your machine - as much as we would all like it to be Mach3 is not Plug'n'Play it does take some effort.
« Reply #5 on: October 18, 2015, 01:23:09 PM »
Sounds like several of Arts agravators showed up . Might want to check his license file (;-).
