Hello Guest it is October 20, 2026, 03:07:09 PM
Author Topic: Random Direction  (Read 11635 times)
Random Direction
« on: October 18, 2015, 07:17:53 AM »
Hopefully a newbie problem :) But when i try to move either the X or Z, it will change direction randomly.  So if i were to be at the center of the table, and push right arrow, to move in that direction, it may go right (+) or left (-), and the same goes for the Z axis.  Any thoughts?
  •  9,374 9,374
Re: Random Direction
« Reply #1 on: October 18, 2015, 07:25:49 AM »
Just a shot in the dark...
If you are using the Parallel Port for communication then it is possible that your PC output voltage is to the 3.3Volt TTL specification and your controller requires a 5Volt TTL signal for correct operation.
« Reply #2 on: October 18, 2015, 08:58:05 AM »
Worth a shot to look into it.  Sent the seller/OEM a message to see what their thoughts are.  Much appreciate the feed back.
« Reply #3 on: October 18, 2015, 09:09:29 AM »
And yes it's a parallel port connection.
  •  9,374 9,374
« Reply #4 on: October 18, 2015, 09:30:15 AM »
You could check by identifying an axis direction pin, then connecting a voltmeter, jogging that axis in one direction should show (approx.) 5 Volts and jogging in the other direction should show (approx.) 0 Volts.
If the maximum voltage shown is only 3.3 Volts then you could perhaps consider fitting your PC with a PCI Parallel Port card which has 5 Volt TTL output.
« Reply #5 on: October 18, 2015, 01:25:47 PM »
Or there are LPT cards that take either  a 3 or < 5v signal lower voltage signal and BOOSTs it up to a clean 5v signal.
(;-0 TP
« Reply #6 on: October 18, 2015, 01:33:28 PM »
Thanks a bunch!!  I have a buddy who may have one and looking to see if it will fit.  If not, there only $10-$15 on ebay, and can have it by Tuesday.  Then its off to the races lol :) Thanks again!!
