Hello Guest it is October 21, 2026, 03:45:16 AM
Author Topic: Slave axis & Kernal speed PROBLEM! Need help please!  (Read 8132 times)
« on: October 17, 2015, 01:53:38 AM »
Hello people,
I have win 7 32 bit with tb6600 board and nema 24.
I have a problem when I slave A to Y, one of the motors run ok and smoothly but the ather motor run slowly with intermittent steps!
I have changed the motors but its still one of them moving bad!
I have tried to change my kernal speed and sometimes its going ok but when restart my Mach3, again the problem appear!! I didn't know what to do! Can someone please help me?
Thanks so much!
Re: Slave axis & Kernal speed PROBLEM! Need help please!
« Reply #1 on: October 17, 2015, 03:05:42 AM »
can you post your XML file for your profile.
What voltage are you suppling the TB6600 boards with?
What pulsewidth do you have set?  CONFIG >> MOTOR TUNING
What steps / mm [or inch] do you have set ?
What maximum velocity mm [or inch] per miniute do you have set?
What maximum acceleration mm [ or inch] / s / s do you have set?
What kernal speed do you have set (25khz seems to most of the time prove to be adequate for most settings for stepper motors)
Rob
Rob
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
« Reply #2 on: October 17, 2015, 02:05:37 PM »
Hello Rob,
First of all thanks about your reply and help with me!
I have a good news about my machine! I have founded the problem that is was the pulsewidth, I have changed it to be 5, its was 2 :)
All times I was with old pc and win xp, this time I have changed to a new pc with win 7 32 bit!
