Hello Guest it is October 20, 2026, 03:07:02 PM
Author Topic: Slave axis & Kernal speed PROBLEM! Need help please!  (Read 8127 times)
« on: October 17, 2015, 01:53:38 AM »
Hello people,
I have win 7 32 bit with tb6600 board and nema 24.
I have a problem when I slave A to Y, one of the motors run ok and smoothly but the ather motor run slowly with intermittent steps!
I have changed the motors but its still one of them moving bad!
I have tried to change my kernal speed and sometimes its going ok but when restart my Mach3, again the problem appear!! I didn't know what to do! Can someone please help me?
Thanks so much!
Re: Slave axis & Kernal speed PROBLEM! Need help please!
« Reply #1 on: October 17, 2015, 03:05:42 AM »
can you post your XML file for your profile.
What voltage are you suppling the TB6600 boards with?
What pulsewidth do you have set?  CONFIG >> MOTOR TUNING
What steps / mm [or inch] do you have set ?
What maximum velocity mm [or inch] per miniute do you have set?
What maximum acceleration mm [ or inch] / s / s do you have set?
What kernal speed do you have set (25khz seems to most of the time prove to be adequate for most settings for stepper motors)
Rob
Rob
Rob
« Reply #2 on: October 17, 2015, 02:05:37 PM »
Hello Rob,
First of all thanks about your reply and help with me!
I have a good news about my machine! I have founded the problem that is was the pulsewidth, I have changed it to be 5, its was 2 :)
All times I was with old pc and win xp, this time I have changed to a new pc with win 7 32 bit!
