Hello Guest it is November 22, 2026, 02:42:20 PM
Author Topic: dxf to g code dimension problem  (Read 11074 times)
« on: October 16, 2015, 04:12:09 AM »
Hello everyone ,
I have problem with converting dxf to nc. I have a lot projects made in tango pcb, in that program am able to export file like dxf, that dxf i load to nc plot to generate g code but dimensions are always a lot smaller than in tango. For a start i make square 100x100mm to make it simple. Is there something i didnt do right ?, Every advice is welcomed . Thanks !
Re: dxf to g code dimension problem
« Reply #1 on: October 16, 2015, 07:21:04 AM »
My guess is that Tango PCB is exporting the dxf in the wrong units.
Offline ZASto
  •  434 434
« Reply #2 on: October 16, 2015, 07:57:50 AM »
Tango PCB exports .dxf in imperial units. If your machine is set in metric units, be shure to add G20 at the beginning of your G code.
My personality is who I am.
« Reply #3 on: October 16, 2015, 08:14:48 AM »
Ok, i will try is it work, thanks a lot !!!
« Reply #4 on: October 20, 2015, 01:36:03 PM »
Just to inform you that  machine worked in real dimensions, thanks for helping !!!
Offline ZASto
  •  434 434
« Reply #5 on: October 20, 2015, 03:41:28 PM »
You're welcome
Nema na čemu.
