Hello Guest it is October 21, 2026, 10:17:02 AM
Author Topic: soft limits not working  (Read 9253 times)
« on: October 13, 2015, 10:53:41 AM »
When I try to turn on soft limits, mach3 states that the "machine out of limits". I have tryed to jog it out of slow zone then turn on soft limits, but same thing happens. Could anyone please tell me how to get soft limits to work
Re: soft limits not working
« Reply #1 on: October 13, 2015, 12:17:43 PM »
Check what your machine coordinates are reading .... Are they outside the limits set in config >>>>> homing limits.... If so rezero your machine coordinates
Rob
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
« Reply #2 on: October 14, 2015, 06:45:58 AM »
the little longer answer is that the softlimits has to know where it is starting from.  Home switches would automate this.  It gives you a machine coordinates zero.  The soft limits work from this point.  But you could always jog your machine to the top of Z and a X & Y to an extreme.  Zero the machine coords. there.  You would have to do this everytime.
