Hello Guest it is November 23, 2026, 12:12:16 PM
Author Topic: Is it possible to open another application from a Mach3 button?  (Read 9245 times)
« on: October 07, 2015, 07:41:29 AM »
I would like to add a button to the Mach3 screen that will open another application on my Windows OS.
I use this other program to create the GCODE files, that I load up into Mach3.
I could load the program from my Start Menu, but I think it would be pretty cool to launch it directly from Mach3.
I tried just putting the path and file name into a Script and linking that to a button but it through up a compile error.
Any ideas?
Thanks Peeps!
Mark
Offline TPS
  •  2,627 2,627
Re: Is it possible to open another application from a Mach3 button?
« Reply #1 on: October 09, 2015, 03:33:20 AM »
simple example to open the calculator
X = Shell("Calc.exe", 1) ' Shell Calculator.
Thomas
« Reply #2 on: October 09, 2015, 03:47:33 AM »
Thanks for that Thomas,
I also found another way - I just changed the G Code Editor path in the General Config options from Notepad to my CAD program, and hey presto, clicking Edit G-Code opens my CAD program.
Think I'll use your method though, so I don;t lose the option of opening Notepad for minor edits.
Mark
