Hello Guest it is October 21, 2026, 07:56:12 AM
Author Topic: Mach 3 demo prg  (Read 9704 times)
Mach 3 demo prg
« on: September 27, 2015, 10:44:07 AM »
Hello all
 Will the demo prg allow you to run a machine albeit restricted
Mick
Re: Mach 3 demo prg
« Reply #1 on: September 27, 2015, 11:37:36 AM »
Yes, but limited to 500 lines of g-code, and a few features that are disabled, like Run From Here.
Re: Mach 3 demo prg
« Reply #2 on: September 29, 2015, 11:09:09 AM »
Thanks for that Gerry
My problem now appears to be with the parrell port not communicating with the  Breakout board  the stepper motor is all wired correct .
Using Windows XP on a tower  the software is loaded the drivers are ok and the axis movement records on  X  Y  Z
Many thanks for your help to date
Mick Magnum
Re: Mach 3 demo prg
« Reply #3 on: September 29, 2015, 11:23:59 AM »
Take it your still having problems, so have you selected the correct parallel port in the config settings and checked the driver is giving the correct pulse.
