Hello Guest it is November 16, 2026, 02:54:03 PM
Author Topic: mach3 Artsoft rectangle at startup doesn't go away  (Read 11453 times)
mbwittig
« on: May 03, 2007, 04:56:57 PM »
Hello all,
The artsoft rectangle that shows at startup doesn't disappear, instead if covers the middle of the controls.  Anyone else have this problem?
-Mike
ynneb
Re: mach3 Artsoft rectangle at startup doesn't go away
« Reply #1 on: May 03, 2007, 05:55:07 PM »
This sounds more like a video card issue than a mach issue. ( Not sure though)
You could try removing the picture from starting up. I think the picture is stored in the Mach folder.
All un tested just ideas.
« Reply #2 on: May 03, 2007, 10:03:43 PM »
Yup, that is a first :(
www.newfangledsolutions.com
www.machsupport.com
