Hello Guest it is October 20, 2026, 02:55:42 PM
Author Topic: Mach 3 or Parellel Port Issue  (Read 8905 times)
« on: September 04, 2015, 02:05:46 PM »
I had my CNC machine set up and working, and my hard drive went.   I have a new computer, Windows 7. 32 bit with parallel port that I added.   I loaded the drives to the computer for the parallel port and it says ok.    I went into properties and found the drive location and entered it into Mach 3, I put the pins in, scale, enabled where I remembered.     When the computer starts up you can hear the stepper motors engage with a slight noise but they will not move with the G code.
The PCI I/O range is EC00-EC07 and EC880-E887, I used EC00.
Mach 3, if I check it says pins not enabled.
Any suggestions?
Thanks Jay ???
Re: Mach 3 or Parellel Port Issue
« Reply #1 on: September 08, 2015, 06:00:03 AM »
Check the technical specifications of the parallel port, unless it's 5v logic you can have problems and most recent PP cards use 3.3v,
 - Nick
« Reply #2 on: September 08, 2015, 09:02:19 AM »
Nick,
You are right, the PCI board is 3.3V.    I will see if I can get the correct one.
I really appreciate you responding, very helpful.
