Hello Guest it is September 26, 2026, 05:59:06 AM
Author Topic: I can't scale any more  (Read 12968 times)
« on: September 04, 2015, 08:54:16 AM »
I'm running Mach3 and I have always been able to scale up or down by changing the values of the X-Y from 1.000 to what I need, until yesterday. I think I have hit a hot key to turn off scaling because on the second screen tab I see the label Scaling Off G50 beside the XYZ display. I'm using it to run a plasma cutter and I don't have a DTHC so I think I hit a button while babysitting the height. Please let me know iff you need more information to help with this problem. Thank you in advance.
Josh
  •  9,374 9,374
Re: I can't scale any more
« Reply #1 on: September 04, 2015, 10:35:31 AM »
Perhaps check that you do not have G50 in the Initialization String (Config / General Config) and also check that there is not a G50 in the Gcode file you are running.
« Reply #2 on: September 04, 2015, 11:04:39 AM »
I'll check but it is the same code I have been scaling the same way for a year.
Thank you for responding
« Reply #3 on: September 04, 2015, 02:20:41 PM »
All that button does is reset the scale back to 1. You never said what happens when you try to set scale. You click on the dro and input a number then press enter. What happens next ?? if nothing are you entering in the number from the numpad ?? is numlock off?
« Reply #4 on: September 04, 2015, 03:03:29 PM »
It won't let me highlight the field at all. I'll see if I can get a screenshot tomorrow
« Reply #5 on: September 05, 2015, 07:41:14 AM »
Hey BR549
 My number pad was off and I freaked before I checked the obvious. I use the scale feature to cut different size butterflies from the same code. Sorry for my panic.
Thank you for the help.
Josh
« Reply #6 on: September 05, 2015, 08:56:42 AM »
Glad you got it sorted, I use scale a lot myself.
