Hello Guest it is November 17, 2026, 01:17:05 AM
Author Topic: Vibrating Motors  (Read 12144 times)
Vibrating Motors
« on: August 24, 2015, 02:36:39 PM »
My hotwire foam cutter is close to being operational. But the motors on the x axis are vibrating/rattling. I found something once which explained "resonance" but I don't see anything in the motor tuning feature iof Mach3. maybe I'm looking in the wrong place. Thanks.
Here's the machine....
https://www.youtube.com/watch?v=U1d8KZKKBhI
Re: Vibrating Motors
« Reply #1 on: August 25, 2015, 07:12:37 PM »
little bit hard to see from the vid, but if you have chain drive ....i found setting one end with vernier calipers ( so they both start at the same place ) and adjusting the  tension at the other end solved my problems ...looks like a cool machine.
« Reply #2 on: August 25, 2015, 08:09:38 PM »
I don't know if this makes any difference but, it's timing belt drive.
« Reply #3 on: August 27, 2015, 09:26:02 PM »
 my gut feeling is that rubber teeth would be less forgiving
slacken off one side  and see if anything changes ,  that way you can put it back how it was .
 i found tension not as important as tuning and lubing my links .
see if some silicone spray or baby powder makes a difference ?
« Reply #4 on: August 30, 2015, 12:38:38 PM »
Thanks. The noise/vibration is in the motors.
  •  9,377 9,377
« Reply #5 on: August 31, 2015, 01:32:06 AM »
Hi 3Dsigns,
Are the motors sometimes noisy when stationary ?
