Hello
Guest
it is
November 07, 2026, 11:03:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
DRO's do not always zero?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DRO's do not always zero? (Read 10199 times)
Davek0974
2,606
on:
August 23, 2015, 08:37:15 AM »
I am setting up a new plasma table and find that when referencing, the DRO's do not always zero after.
Usually works but not always???
I am referencing X normally (DoButton ( 22 ) i think ) but Y is slaved and I'm using RefCombination ( 10 ) in the ref button script.
Any thoughts?
ger21
6,295
Re: DRO's do not always zero?
Reply #1 on:
August 23, 2015, 08:55:30 AM »
Check "Auto Zero" in Config > Homing/Limits
Davek0974
2,606
Reply #2 on:
August 23, 2015, 09:01:22 AM »
Apologies, should have said that, yes it's checked.
ger21
6,295
Reply #3 on:
August 23, 2015, 09:59:08 AM »
If you have offsets set, the DRO's will display the offset, as homing zeroes the machine coordinates, not necessarily the DRO's.
Davek0974
2,606
Reply #4 on:
August 23, 2015, 10:04:17 AM »
Ah, that might be it, will check tomorrow, thanks
Print
Pages:
1
Go Up
« previous
next »
