Hello Guest it is November 07, 2026, 11:03:30 AM
Author Topic: DRO's do not always zero?  (Read 10202 times)
Offline Davek0974
  •  2,606 2,606
« on: August 23, 2015, 08:37:15 AM »
I am setting up a new plasma table and find that when referencing, the DRO's do not always zero after.
Usually works but not always???
I am referencing X normally (DoButton ( 22 ) i think ) but Y is slaved and I'm using RefCombination ( 10 ) in the ref button script.
Any thoughts?
Re: DRO's do not always zero?
« Reply #1 on: August 23, 2015, 08:55:30 AM »
Check "Auto Zero" in Config > Homing/Limits
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: August 23, 2015, 09:01:22 AM »
Apologies, should have said that, yes it's checked.
« Reply #3 on: August 23, 2015, 09:59:08 AM »
If you have offsets set, the DRO's will display the offset, as homing zeroes the machine coordinates, not necessarily the DRO's.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: August 23, 2015, 10:04:17 AM »
Ah, that might be it, will check tomorrow, thanks
