Hello Guest it is November 12, 2026, 04:34:36 PM
Author Topic: Mach3 will not load file  (Read 13359 times)
« on: August 14, 2015, 09:12:17 AM »
Newbie here, just got a 3040T with mach3. Mach3 would not install on my comp so i copied the Mach3 setup to my hard drive and then installed mach3. The problem is when I load a file to demo it doesn't show a pic on the job display, the file reads it is there but no display.
Am I supposed to buy a license? What am I missing? Thanks so much
Re: Mach3 will not load file
« Reply #1 on: August 14, 2015, 09:39:32 AM »
If it loads G code but doesn't show the toolpath it means the tool path coordinates don't fall within the travels of the machine you have set up.
« Reply #2 on: August 14, 2015, 11:06:10 AM »
Is there an error message?
« Reply #3 on: August 14, 2015, 01:48:03 PM »
No error msg.
« Reply #4 on: August 14, 2015, 01:54:56 PM »
What should the toolpath coordinates be?
« Reply #5 on: August 14, 2015, 08:21:19 PM »
Make sure your not in table display mode, and regen the toolpath.
« Reply #6 on: August 14, 2015, 09:20:04 PM »
Double check to make sure that the toolpath is NOT disabled
« Reply #7 on: August 14, 2015, 10:33:50 PM »
I did both of those and it didn't work.  It downloads the file but doesn't show up on display.
