Hello Guest it is October 25, 2026, 12:25:20 AM
Author Topic: reference all home - probblem adding to stock button code  (Read 11175 times)
« on: August 08, 2015, 08:26:03 PM »
 I'm a Mach3 beginner.  I have a small CNC router I built a year or so ago.  My machine is a fixed gantry and my home switches are located in such a way that my table homes to the rear of the machine (min Y) when I execute reference all home.  After that, I almost always move the table back to the front of the machine (max Y) to deal with work pieces.  That works fine but I wanted to automate that move back to the front after I reference home.
I went to Operator, Edit Button Script and changed the "reference all home" code as follows:
Code: [Select]
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
Code"G0 Y14.7"
It sort of works.  But it executes the move to 14.7 first, then does the reference all home.  Is there a way I can get that command to happen after the reference all home?
Scott
« Last Edit: August 08, 2015, 08:28:09 PM by shorton »
Re: reference all home - probblem adding to stock button code
« Reply #1 on: August 09, 2015, 02:48:02 PM »
I figured it out.  This seems to work:
Code: [Select]
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
While (IsMoving())
Wend
code "g53 x1 y14.7"
« Reply #2 on: August 09, 2015, 05:23:14 PM »
It should be:
While IsMoving()
Wend
You should also have one after
code "g53 x1 y14.7"
Like this:
Code: [Select]
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
While IsMoving()
Wend
code "g53 x1 y14.7"
While IsMoving()
Wend
« Reply #3 on: August 09, 2015, 05:47:49 PM »
Thanks Gerry.  I'll correct it.  Much appreciated.
« Reply #4 on: August 09, 2015, 05:48:45 PM »
While I'm at it, what do these do?  They have no apparent effect, although I expect they are there for a reason and doing something :)
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
« Reply #5 on: August 09, 2015, 07:03:42 PM »
They zero encoder DRO's I think.
Most people don't need them.
