Hello Guest it is November 13, 2026, 03:07:43 PM
Author Topic: Machine goes wild with uncontrolled jog  (Read 37950 times)
Re: Machine goes wild with uncontrolled jog
« Reply #10 on: July 30, 2015, 12:27:54 PM »
Shift arrow jogging done here everyday the plasma machine runs. No problems here and I have  NEVER heard of it OTHER than with a plugin based controller/pendant.
« Reply #11 on: July 30, 2015, 12:53:03 PM »
It happens when you leave it in step mode and hit shift and an arrow key.
« Reply #12 on: July 30, 2015, 01:16:49 PM »
OK I just tested it again . Same thing it follows all functions exactly. Set for Step JOg and each arrow down jogs the step. Prees shift and it runs in Cont just as it should any combination of press hold with Shift and arrow works fine. ????
Now that is Version v.062 running the LPT driver. NO plugins active.
NOW just a note, SOME pc's /keyboards have a weird repeat feature THAT CAN cause what you are seeing. Normally you can turn it off , sometimes you cannot.  SOme Remote keyboards(wireless) can do that IF the batteries run LOW.
« Last Edit: July 30, 2015, 01:19:26 PM by BR549 »
« Reply #13 on: July 30, 2015, 01:33:40 PM »
Version R3.043.022 - PP
Can't make it happen here. Works perfectly.
« Reply #14 on: July 30, 2015, 01:36:47 PM »
Yea, it must be a plugin thing. I'm using ESS on the mill. I've taught myself to be sure I'm out of step mode before making any fast moves :)
« Reply #15 on: July 30, 2015, 01:37:31 PM »
I do have a pendant.  IIRC it's a problem on the other machine I have too, which does not have a pendant hooked up to it.
« Reply #16 on: July 30, 2015, 04:52:08 PM »
What version of M3 does this go nutty on ?
Russ
Might make no difference ... just curious .... if you don't mind.
Russ
« Reply #17 on: July 30, 2015, 05:36:24 PM »
On
Russ
Russ
On my mill, I have .062
« Reply #18 on: August 01, 2015, 06:56:19 AM »
Runaway has been a problem for a LONG while now. I always use the keyboard for input, so it has bit me many times. It bothers me so much, I will not let anybody run the machine, unless it's just **open vise, change part, hit GO button. Rinse. Repeat.** I HATE this bug. http://www.machsupport.com/forum/index.php/topic,24665.10.html
« Reply #19 on: August 01, 2015, 12:58:35 PM »
Ok looked at the old post Sam linked to and tried it out and indeed it does continue if you release the shift first but only if  in  Step mode.
Can someone with the PP also try that to see if it also happens with it or whether it is just external devices?
