Hello Guest it is October 21, 2026, 03:13:43 AM
Author Topic: Output signal trouble with flood relays.  (Read 11125 times)
« on: April 30, 2007, 09:34:11 AM »
I noticed when I run a simulated program on Mach3, the diagnostics page shows that the output for the flood relays is pulsing.  My question is:
       - Is the signal coming from the computer output pin pulsing (switching from active high to active low)?
        -If the solid state relay is directly wired to this pin, will it pulse on and off?
        -How can I make it so the relay stays on after the appropiate M code comand , and turns off when told too.
Re: Output signal trouble with flood relays.
« Reply #1 on: April 30, 2007, 10:18:13 AM »
Hey Glen,
Yes
If it is a 5volt trigger it will.
M8 turns on flood, M9 turns it off.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: April 30, 2007, 02:48:25 PM »
Hi, Glen
No, It is only pulsing the led on the screen.
No, It will be in a solid state, High or low depending how you set the setting in Config, Ports & Pins, Output's, (Active Hi or Low).
If it is a 5volt trigger it will. (Most solid state relays are 3 - 30 volts).
Hope this clears the Air(Flood), Chip
« Reply #3 on: April 30, 2007, 04:22:08 PM »
Glen, Chip is right. I hope this scrren shot helps too.
