Hello Guest it is October 25, 2026, 05:37:43 PM
Author Topic: Arrow keys don't work  (Read 37235 times)
Re: Arrow keys don't work
« Reply #10 on: July 16, 2015, 04:43:49 AM »
Ok so reinstall Mach3.
Regards
Charlie M.
« Reply #11 on: July 16, 2015, 05:01:52 AM »
I reinstalled March 6 or more times with Win7 and XP. Result is the same.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: July 16, 2015, 06:53:05 AM »
When you say "Arrow keys don't work". Do you mean when you jog (press the arrow keys) the DRO values don't change or just that the axes don't move?
When you say "G-code doesn't execute" do you mean the gcode doesn't "run" in the gcode window and the DROs don't change values or do you mean the axes don't move?
« Reply #13 on: July 16, 2015, 06:54:18 AM »
Arrow keys work with other applications. Pay attention, please, that G-code doesn't execute also. It means that Mach works incorrectly.
Did not see any mention of the axis' being enabled.
Rename and post the XML of the profile you are using, someone might see something there.
Russ
« Reply #14 on: July 16, 2015, 07:11:23 AM »
I mean that  he DRO values don't change.
I mean that the gcode doesn't "run" in the gcode window and the DROs don't change values.
« Reply #15 on: July 16, 2015, 07:36:02 AM »
Are you using a PP?
1.Run the driver test
2. Sure that the PP address is correct in your config.
Attach your xml as requested.
No other comment's from here until it's posted.
« Last Edit: July 16, 2015, 07:37:48 AM by RICH »
« Reply #16 on: July 16, 2015, 09:43:45 AM »
RICH,
What does PP adress mean?
« Reply #18 on: July 16, 2015, 12:55:52 PM »
Pirated software.
Ya gotta fix that FIRST !
Russ
« Reply #19 on: July 16, 2015, 04:14:59 PM »
This isn't a pirate software.
I deleted everything from HDD.
I reinstall windows XP SP2(licensed).
I upgraded it to SP3 with a downloaded fom MS web exe.file.
I downloaded a 66 version of March from this site one more time.
I installed Mach one more time.
But no result, arrow key don't work, g-code doesn't run.
Hot keys config: https://drive.google.com/file/d/0B1Eh2NhtXvVIdHpFRloweEZpZ3c/view?usp=sharing
MPG mode: https://drive.google.com/file/d/0B1Eh2NhtXvVIZ1d4T3VDV1pHclU/view?usp=sharing
Driver test: https://drive.google.com/file/d/0B1Eh2NhtXvVIbk1VQ3NrRzlwT0E/view?usp=sharing
Vit
