Hello Guest it is October 25, 2026, 04:37:37 PM
Author Topic: Arrow keys don't work  (Read 37232 times)
« on: July 14, 2015, 03:16:35 PM »
Hi averyone!
I have Windows XP Prof SP2 + Mach3 demo (just dowloaded). Jog ON/OFF and RESET are green. MPG MODE is Cont. What is proplem? What should I do?
Thank you in advance,
Vitaly
Re: Arrow keys don't work
« Reply #1 on: July 14, 2015, 04:34:07 PM »
Goto Config/System hot keys and make sure they are set correctly.
Regards
Charlie M.
« Reply #2 on: July 14, 2015, 06:36:17 PM »
You also need to have a feed speed entered or the jog will be really really slow. On MDI enter F20 for a feed rate of 20 mm or inches.
« Reply #3 on: July 14, 2015, 06:55:56 PM »
upgrade to SP3 as well.
Wes
« Reply #4 on: July 14, 2015, 11:44:41 PM »
Thank you every one!
I've checked confyg\ hotkeys. They are 39, 37, 38, 40, 33, 34. Seems to be OK.
I've changed feed to 20 mm/min.
No result. The arrow keys don't work.
« Reply #5 on: July 15, 2015, 03:11:40 AM »
I upgraded to SP3. No result.
I checked the Mach on another Laptop with Win 8.1. Arrow keys work, a program is excecuted, but no LPT.
Please, help.
« Reply #6 on: July 15, 2015, 06:54:36 AM »
Check your Num lock / Scroll lock.
Reassign the keys using the pop up dialog instructions maybe.
Russ
« Reply #7 on: July 15, 2015, 09:00:11 AM »
1. I chrcked Num lock / Scroll lock.
2. I Reassigned the keys using the pop up dialog instructions
No results
March doesn't execute a program exept feed rate.
« Reply #8 on: July 15, 2015, 04:32:29 PM »
Stumer,
          Does your keyboard arrow keys work with any other software? For example in notepad can you move the cursor using the arrow keys?
Regards
Charlie M.
« Reply #9 on: July 16, 2015, 01:32:16 AM »
Charlie_M,
Arrow keys work with other applications. Pay attention, please, that G-code doesn't execute also. It means that Mach works incorrectly.
