Hello
Guest
it is
October 25, 2026, 05:37:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Arrow keys don't work
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Arrow keys don't work (Read 37236 times)
Sturmer
12
on:
July 14, 2015, 03:16:35 PM »
Hi averyone!
I have Windows XP Prof SP2 + Mach3 demo (just dowloaded). Jog ON/OFF and RESET are green. MPG MODE is Cont. What is proplem? What should I do?
Thank you in advance,
Vitaly
Charlie_M
189
Re: Arrow keys don't work
Reply #1 on:
July 14, 2015, 04:34:07 PM »
Goto Config/System hot keys and make sure they are set correctly.
Regards
Charlie M.
garyhlucas
660
Reply #2 on:
July 14, 2015, 06:36:17 PM »
You also need to have a feed speed entered or the jog will be really really slow. On MDI enter F20 for a feed rate of 20 mm or inches.
ozwes007
105
Reply #3 on:
July 14, 2015, 06:55:56 PM »
upgrade to SP3 as well.
Wes
Sturmer
12
Reply #4 on:
July 14, 2015, 11:44:41 PM »
Thank you every one!
I've checked confyg\ hotkeys. They are 39, 37, 38, 40, 33, 34. Seems to be OK.
I've changed feed to 20 mm/min.
No result. The arrow keys don't work.
Sturmer
12
Reply #5 on:
July 15, 2015, 03:11:40 AM »
I upgraded to SP3. No result.
I checked the Mach on another Laptop with Win 8.1. Arrow keys work, a program is excecuted, but no LPT.
Please, help.
Overloaded
4,923
Reply #6 on:
July 15, 2015, 06:54:36 AM »
Check your Num lock / Scroll lock.
Reassign the keys using the pop up dialog instructions maybe.
Russ
Sturmer
12
Reply #7 on:
July 15, 2015, 09:00:11 AM »
1. I chrcked Num lock / Scroll lock.
2. I Reassigned the keys using the pop up dialog instructions
No results
March doesn't execute a program exept feed rate.
Charlie_M
189
Reply #8 on:
July 15, 2015, 04:32:29 PM »
Stumer,
Does your keyboard arrow keys work with any other software? For example in notepad can you move the cursor using the arrow keys?
Regards
Charlie M.
Sturmer
12
Reply #9 on:
July 16, 2015, 01:32:16 AM »
Charlie_M,
Arrow keys work with other applications. Pay attention, please, that G-code doesn't execute also. It means that Mach works incorrectly.
Print
Pages:
1
2
3
Go Up
« previous
next »
