Hello Guest it is November 13, 2026, 03:00:58 PM
Author Topic: Mach 3 starts on its own  (Read 8715 times)
« on: June 29, 2015, 12:42:30 PM »
I turned on my flame table today, powered everything up, and pressed the red RESET button and the Y axis started to move on its own.   I have not made any changes, or added any updates.
I am using Toms CandCNC BOB, and it has a LED for each axis and it flashes when Mach3 tells the axis to move.   This LED for the Y axis is flashing, so Mach is telling the axis to move.
any idea where to start?
Steve
Re: Mach 3 starts on its own
« Reply #1 on: June 29, 2015, 01:56:35 PM »
YEP, do you have the handpendant PN200 ???
« Reply #2 on: June 29, 2015, 09:23:48 PM »
TP-
Good guess!  I unplugged the pendant and the movement stopped.
When I plugged the pendant back in, it started to move again.
I use the probing routine to find the top of the plate.   This is not working now either.
When the program runs, it goes to the first top of the plate z move, then scrolls to the end of the program fast.
the x and y axis move on their own very slowly.
could the plug in be corrupted ?
steve
