Hello Guest it is November 22, 2026, 06:53:07 AM
Author Topic: MACH3 Demo  (Read 12234 times)
MACH3 Demo
« on: June 23, 2015, 07:38:41 AM »
Hello,
Should I be able to test MACH3 software (demo) before I purchase ?
Here's my story ...... MACH2 will run my mill, XP only.  I downloaded MACH3 (demo), using a different pc
with Win 7 (no parallel port)  and a UC100 cable. When I start the software I have a choice for what cable to use.
I cannot get no machine response at all meaning, jog or sample program run.
Any help at all will be very much appreciated.
Thank you.
Re: MACH3 Demo
« Reply #1 on: June 24, 2015, 06:10:18 AM »
The demo runs with a limited number of lines of code for PP, not sure about with a motion controller but I can't see why not,
 - Nick
Re: MACH3 Demo
« Reply #2 on: June 24, 2015, 09:21:55 AM »
Thank you Nick.
I'm guessing it's a problem somewhere in the configuration.
Since I have the UC100 cable, I'm going to try UCCNC software.
Re: MACH3 Demo
« Reply #3 on: June 26, 2015, 02:59:25 PM »
I didn't think M3 worked without a parallel port, unless you had an external motion device.......ie smoothe stepper?  Also Win 7 32 bit is only version I think.  I get 3 and 4 confused a lot.
Re: MACH3 Demo
« Reply #4 on: June 26, 2015, 08:12:45 PM »
The UC100 is an "external motion device".
Re: MACH3 Demo
« Reply #5 on: June 27, 2015, 06:49:05 AM »
Thank you everyone.
Up and running with other software.
