Hello Guest it is November 22, 2026, 12:38:03 PM
Author Topic: Cant figure out Mach2 Configuration for XS-3525/8S-4  (Read 11158 times)
Severance17
« on: April 26, 2007, 07:06:17 PM »
I have a Taig mill with four axis controller (XS-3525/8S-4) and just purchased mach2 as sugested by the controllers web site but i cant seem to get the board to respond to any command sent to the board by the computer. i ust to use linux CNC which worked perfectly except you could only use one file type. so i switched to mach but now can not figure out how to get my machine up and running. if anyone could help with setup that would be great i have almost completed the users guide and didnt seem to help. any input would be appreicated.
Re: Cant figure out Mach2 Configuration for XS-3525/8S-4
« Reply #1 on: April 27, 2007, 10:45:44 AM »
Scott, attach your xml file and someone will have a look and see if they can spot anything.
« Reply #2 on: April 27, 2007, 10:49:00 AM »
BTW might be better with Mach3, its light years ahead of Mach2.
