Hello Guest it is November 23, 2026, 07:19:11 AM
Author Topic: Disconnect Shuttle Pro - HOW?  (Read 9475 times)
« on: June 06, 2015, 08:11:27 AM »
I was using Shuttle pro on my Mach3.
Great, but it was not reliable.  I cleaned the insides a couple of times, and it worked for a while - but
ANYWAY - I bought a VistaCNC Mach3 pendant and installed the plugin.
I tries to disconnect the shuttle pro by clicking the green check mark to change it to a red X - but imediately get an error message and Mach3 shuts down.
How do I disable the shuttle pro?
Re: Disconnect Shuttle Pro - HOW?
« Reply #1 on: June 06, 2015, 10:43:13 AM »
Delete the plugin from the mach3\plugins folder.
« Reply #2 on: June 06, 2015, 10:50:20 AM »
Thanks GER
Does it matter if I just leave it in there and active?  Will it be conflicting with my IMach MPG
« Reply #3 on: June 06, 2015, 11:15:58 AM »
If it's not causing problems, you can leave it.
