Hello Guest it is November 22, 2026, 06:08:41 PM
Author Topic: UC 100 setting probe on mach3  (Read 24623 times)
« on: June 05, 2015, 03:58:35 PM »
Someone can help me to activate touch probe with uc 100 usb parallel controller?
Re: UC 100 setting probe on mach3
« Reply #1 on: June 06, 2015, 05:50:31 PM »
Hi alza,
     have you got it setup to work with mach3?
Regards
Charlie M.
« Reply #2 on: June 06, 2015, 09:44:32 PM »
Yes but is impossible to configure it, auto tool setting probe don't recognize lpt port one. What i can do?
« Reply #3 on: June 07, 2015, 01:38:37 AM »
 do you mean the auto tool zero in mach3?
Regards
Charlie M.
« Reply #4 on: June 07, 2015, 01:42:19 AM »
Ok not enough info on my part.  have you loaded a zeroing script in the auto tool button? What pin do yo have your probe set ? what sort of breakout board do you have?
Regards
Charlie M.
« Reply #5 on: June 08, 2015, 05:40:38 AM »
Is impossible to add! Because is not figured as lpt as needed. In diagnostic, pin ports are not visible but only in uc100 panel (15 imp.).  I've a cnc 3020 last type with black box controller.
« Last Edit: June 08, 2015, 05:44:10 AM by alza »
« Reply #6 on: June 08, 2015, 06:20:13 AM »
OK. sorry for your frustration. your best bet might to contact the manufacturer and see what they say.
Regards
Charlie M.
« Reply #7 on: June 08, 2015, 03:02:00 PM »
They have already responded and said they did not know how to go about Mach 3 ! hahaha They sell them and do not know anything , crazy stuff .
« Reply #8 on: June 08, 2015, 05:18:35 PM »
OK the UC100 is a straight USB controller (nothing to do with the LPT port).  You should have pins on the UC100 that you hook the probe to. The UC100 then translates those pins back to Mach3. You would then need to set the pins in Mach3 that MATCH what the UC100 expects for the probe.
IF the UC100 even supports a probe. The info SHOULD be in the UC100 setup manual.
Just a thought, (;-) TP
« Reply #9 on: June 08, 2015, 07:43:06 PM »
It does.
