Hello Guest it is November 22, 2026, 06:08:45 PM
Author Topic: UC 100 setting probe on mach3  (Read 24624 times)
Re: UC 100 setting probe on mach3
« Reply #10 on: June 09, 2015, 05:39:07 AM »
I already tried does not work, read the top messages.
Offline derek
  •  200 200
« Reply #11 on: June 09, 2015, 05:47:26 AM »
I have probes on pin 15 on two machines and they work fine.
Check your wiring and whatever script you're using for the probe.
If the probe activates pin 15 LED on the UC100 plugin then it's your script. If it doesn't activate it then it's your probe, the UC100 or your wiring.
« Reply #12 on: June 09, 2015, 05:51:00 AM »
I must write a script? For this? I don't understand!
Offline derek
  •  200 200
« Reply #13 on: June 09, 2015, 05:58:49 AM »
Something has to tell the machine what to do. I'm no expert as I use Calypso screen sets and the buttons for probing are all pre scripted. G31 is a probing code. Do some searching on that.
