Hello Guest it is November 22, 2026, 09:27:31 AM
Author Topic: pls help ........... with the limit switch  (Read 9735 times)
« on: June 05, 2015, 05:56:53 AM »
hi all
i'm trying to set up limit switches with strategy of only two limit for single axis as ++,-- ,home
i have read the manual but i want to understand the wiring better and the configuration
also i tried the override limit switch by auto in the sittings screen but  how it could be made manually
that the manual does not cover this will
please help and refer if there is a supporting vedio ???
Re: pls help ........... with the limit switch
« Reply #1 on: June 06, 2015, 07:30:06 PM »
 Hi this is how I have my limit switches on my router. reason being I hve more switches then inputs. I just simply wire them is series. similar to this.
http://www.mycncuk.com/attachment.php?attachmentid=5351&d=1329160037
Regards
Charlie M.
« Reply #2 on: June 17, 2015, 08:05:04 AM »
thanks alot man that is very helpful
« Reply #3 on: June 17, 2015, 04:35:11 PM »
Hi Glad I could help.
Regards
Charlie M.
