Hello
Guest
it is
October 24, 2026, 06:31:39 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Invalid value 4 for a boolean key "MatchCase" in config file
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Invalid value 4 for a boolean key "MatchCase" in config file (Read 21012 times)
TimGS
108
Re: Invalid value 4 for a boolean key "MatchCase" in config file
Reply #10 on:
May 29, 2015, 07:59:31 AM »
It is an annoying message. The directory must be hidden...I deleted just about everything and ran the mcLuaEditor.exe from a memory stick and still had the same problem...just on that computer.
I ran the mcLuaEditor.exe on another computer and it ran just fine.
TimGS
108
Reply #11 on:
May 29, 2015, 01:53:07 PM »
I may have found something while at lunch today....
../AppData/.../wxLuaIDE.ini
I will look for that same .ini file when I get home.
TimGS
108
Reply #12 on:
May 29, 2015, 04:43:56 PM »
Fixed It!!!!!
I corrupted the wxLuaIDE.ini file; probably while editing a script then crashing Mach4 and killing the process. ...I am sure nobody has ever done that here
Running Windows 8.1 64-bit
I tried to change the value on an older machine to recreate the suspected problem but Lua automatically fixed the problem; but it did not fix it here on this machine.
The following is a snapshot of the location and the file you need to edit.... In my case, change from the MatchCase=4 to MatchCase=1 or =0...this is part of the Find Function. (The error message was telling us what the problem was. It just didn't tell us where the file was). Note: This file is written every time you close a LuaEditor window.
Screwie Louie
166
Reply #13 on:
May 30, 2015, 03:16:51 AM »
Holy sh!tB@lls batman!! That is freakin awesome! ?Good looking out Tim. Thanx for letting us know if we ever encounter that issue!
--josh
Screwie Louie
166
Reply #14 on:
May 30, 2015, 03:37:46 AM »
by the way, I just changed my name from 20,000 Axes to just my first name....just so your are like "who the heck is this guy?"
TimGS
108
Reply #15 on:
May 30, 2015, 07:31:10 AM »
Yep... when I saw your first name I thought it was 20,000 Ex's.... I have one or two of those
Print
Pages:
1
2
Go Up
« previous
next »
