Hello Guest it is November 01, 2026, 11:52:45 AM
Author Topic: Offset problem  (Read 9669 times)
Offset problem
« on: April 24, 2007, 03:08:40 PM »
Hello all,
Mach3 V2.00.65 and licensed LazycamPro
Two problems:
1) The offset corresponds to the diameter of the tool whereas it should correspond to the radius.
2) Even problem for the internal pocketting, the internal pocket is too small of a 2*radius of tool. Just for the first offset, the remainder of the pocket is correct.
I had a pocket to make with a tool of 14mm I initially had to make an offset for a tool of D:7mm before making the pocket with the tool of D:14mm!
Could somebody check this problem?
Thank you in advance
Francis
Re: Offset problem
« Reply #1 on: April 24, 2007, 10:11:05 PM »
We know about the problem and will be fixed for the next release.
Thank you for telling us about it
Brian
www.newfangledsolutions.com
www.machsupport.com
