G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: ftissera on April 24, 2007, 04:08:40 PM
Hello all,
Mach3 V2.00.65 and licensed LazycamPro
Two problems:
1) The offset corresponds to the diameter of the tool whereas it should correspond to the radius.
2) Even problem for the internal pocketting, the internal pocket is too small of a 2*radius of tool. Just for the first offset, the remainder of the pocket is correct.
I had a pocket to make with a tool of 14mm I initially had to make an offset for a tool of D:7mm before making the pocket with the tool of D:14mm!
Could somebody check this problem?
Thank you in advance
Francis
We know about the problem and will be fixed for the next release.
Thank you for telling us about it
Brian
