Hello Guest it is October 21, 2026, 03:46:50 PM
Author Topic: Mach 3 and UC100 usb motion control install problem....  (Read 23177 times)
« on: May 23, 2015, 01:29:57 PM »
So I finally got to the point of getting my home cnc machine ready for running.
Problems right off the get go with the driver install.
I'm installing on a windows 7 64bit system.
version of Mach 3 is Version R3.043.066
and installing a UC100 USB motion controller (V2.148) since there is no parallel port.
When I start mach these errors pop up:
Plugin DLL Defective. Reload
UC100 V2_148.dll - Defective Plugin Found..ignoring
So now what ?!
Do I have to update Mach3?
Do I have to update the uc100?
any help much appreciated,
thx
Re: Mach 3 and UC100 usb motion control install problem....
« Reply #1 on: May 23, 2015, 01:51:31 PM »
Is your controller card working after you open the mach3 and click ok for errors?
I was same problem with my usb card but I didnt work on it after I understand my card is not supporting thc signals. But after I click ok for errors the card was working...
I think its an installation problem or bug, just a thought.
« Reply #2 on: May 23, 2015, 02:01:45 PM »
rookie errors...
didn't realize i had to have the card actually connected for the install to work correctly....no errors now
« Reply #3 on: June 15, 2015, 02:39:52 PM »
how to configure autozero with touch plate in mach3? can you help me?
« Reply #4 on: February 17, 2017, 08:06:14 PM »
I also have a install problem with this install.  Following the directions from UC100 I was in a bit of a hurry.  I didn't see all the options on the window that dropped saying check . well UC 100 wa checked so I said install and opened Mach 3 as instructed,  the box pops up wit uc300 and uc400 , I cant get rid of them, , any suggestions.
« Reply #5 on: February 18, 2017, 05:59:09 AM »
Check the Mach3\plugins folder and delete the UC300 and UC400 plugins. Not sure how you would have installed those, though, with the UC100 installer??
Best to just delete all the plugins and start over.
Go here, and download the plugin for manual installation. (option 3) http://www.cncdrive.com/UC100.html
Copy it to Mach3\plugins, and then double click on it. It'll say "plugin installed"
Then download the USB drivers, and install them.
It should then work fine.
« Reply #6 on: February 19, 2017, 01:17:48 AM »
thanks Gerry  I did all this and it ran once then I was programing the steppers and I get the  message that the driver cant be found, check cables   so did that and I see the green light and the blue one.  The directions say to download the  USB drivers again.  Can you leed me to where the proper drivers are.
its great some people take time to help unknowledgeable people or  in my case dummy's like me lol
