Hello Guest it is October 16, 2026, 01:58:01 PM
Author Topic: lazycam cut order  (Read 9653 times)
Offline moxy
  •  34 34
lazycam cut order
« on: April 23, 2007, 04:24:31 AM »
Hi Guys, When I post a gcode file using lazy cam I end up with quite a lot of "intercut jogging" which adds a lot of time to the job overall. I use the optomise option and that helps a bit but......... Is there a way that I can edit the cut order within lazycam or perhaps lazycam pro will include such an option. Any help?
Regards
Les
Re: lazycam cut order
« Reply #1 on: April 23, 2007, 07:31:21 AM »
Les,
This is on the books to be added... we are working on the new interface and after that we will make it so you can change the cut order
www.newfangledsolutions.com
www.machsupport.com
