Hello Guest it is November 19, 2026, 03:44:42 AM
Author Topic: Macro trigger in C++  (Read 22565 times)
« on: May 12, 2015, 02:36:25 PM »
I always seem to come up with the fun ones:
I am having an issue where I am triggering a macro to run via the MachRemote application using scripter.DoOEMButton(301) call.  I have set 301 to the appropriate macro and the vbscript will run as it should and does what I need when I trigger it in the vbscript editor.  However, when I trigger it using the scripter.DoOEMButton, it will load the file but will display the "Path Generating" Dialog box and not go any further.  I can hit cancel on the box and then continue by stopping and starting the macro in Mach 3, but that kind of defeats the whole point of what I want to accomplish.  Any suggestions on how to get Mach 3 to move past this "Path Generating" dialog box automatically?
Re: Macro trigger in C++
« Reply #1 on: May 12, 2015, 03:14:14 PM »
« Reply #2 on: May 12, 2015, 04:37:38 PM »
Thanks for the reply, unfortunately this did not resolve the issue.   :'(
