Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: DBTguy9 on May 12, 2015, 03:36:25 PM
I always seem to come up with the fun ones:
I am having an issue where I am triggering a macro to run via the MachRemote application using scripter.DoOEMButton(301) call. I have set 301 to the appropriate macro and the vbscript will run as it should and does what I need when I trigger it in the vbscript editor. However, when I trigger it using the scripter.DoOEMButton, it will load the file but will display the "Path Generating" Dialog box and not go any further. I can hit cancel on the box and then continue by stopping and starting the macro in Mach 3, but that kind of defeats the whole point of what I want to accomplish. Any suggestions on how to get Mach 3 to move past this "Path Generating" dialog box automatically?
You can try this :
http://www.machsupport.com/forum/index.php/topic,20127.0.html
It might help.
Russ :)
Thanks for the reply, unfortunately this did not resolve the issue. :'(
