Hello Guest it is November 22, 2026, 04:31:15 PM
Author Topic: Input and Output Signal List Location  (Read 14695 times)
Offline TimGS
  •  108 108
« on: May 05, 2015, 08:33:44 AM »
Brian,
Is the latest Input and Output Signal List located under "Mach Signals" in the "Mach4 Core API" (Found in the "../documents" folder)?
Offline dude1
  •  1,253 1,253
Re: Input and Output Signal List Location
« Reply #1 on: May 05, 2015, 02:43:29 PM »
if you look in tool box`s there`s list`s of all sort`s of things
Offline TimGS
  •  108 108
« Reply #2 on: May 05, 2015, 04:51:28 PM »
Thank You ... I did not know that it existed....Found it...Thank You
Offline TimGS
  •  108 108
« Reply #3 on: May 06, 2015, 06:56:31 AM »
The toolbox has lots of great information but not what I was looking for...The current API listing.  :(
« Reply #4 on: May 06, 2015, 08:00:54 AM »
look in the "Mach4CoreAPI.chm" under docs.
Scott
Offline TimGS
  •  108 108
« Reply #5 on: May 06, 2015, 08:17:38 AM »
If you mean in the Mach 4 installed directory under documents.... I did.  It just did not seem up to date.
If you mean in the toolbox... I still couldn't find it... :(
Offline TimGS
  •  108 108
« Reply #6 on: May 06, 2015, 08:24:32 AM »
....sorry, I meant list of "INPUT and OUTPUT" Signals....in this thread
Offline TimGS
  •  108 108
« Reply #7 on: May 20, 2015, 07:33:39 AM »
Thank You Poppa Bear... I did find the "Input" and "Output" Signal list using the "Index" tab in "Mach4CoreAPI.chm".
