Mach Discussion => Mach4 General Discussion => Topic started by: TimGS on May 05, 2015, 09:33:44 AM
Brian,
Is the latest Input and Output Signal List located under "Mach Signals" in the "Mach4 Core API" (Found in the "../documents" folder)?
if you look in tool box`s there`s list`s of all sort`s of things
Thank You ... I did not know that it existed....Found it...Thank You
The toolbox has lots of great information but not what I was looking for...The current API listing. :(
look in the "Mach4CoreAPI.chm" under docs.
Scott
If you mean in the Mach 4 installed directory under documents.... I did. It just did not seem up to date.
If you mean in the toolbox... I still couldn't find it... :(
....sorry, I meant list of "INPUT and OUTPUT" Signals....in this thread
Thank You Poppa Bear... I did find the "Input" and "Output" Signal list using the "Index" tab in "Mach4CoreAPI.chm".
