Hello Guest it is November 24, 2026, 07:08:38 AM
Author Topic: Cutting Aluminium  (Read 21776 times)
Cutting Aluminium
« on: May 05, 2015, 07:03:52 AM »
I bet it has been asked a thousand times but here goes.
I'm attempting to cut some Aluminum sheet 12.5" thick,
Some pockets will go right through up to 2" diameter. A profile around the plate will be approx 9" x 4"
There will be a few 6mm slots.
My bench mills fastest speed is 2100rpm
If I use a 10mm 3 flute slot drill and cut at 0.5mm per pass , what speed should my table be running at in inches per minute to get best results.
I'll mist with white milky stuff from a spray bottle.
Is .25mm per pass too little ? What is the easiest grade of aluminum to cut?
George
One step at a time!
Re: Cutting Aluminium
« Reply #1 on: May 05, 2015, 07:08:23 AM »
I'm attempting to cut some Aluminum sheet 12.5" thick ..............
George
Hi George,
 No, actually I think that is a first.  ;D
Russ
« Reply #2 on: May 05, 2015, 07:34:14 AM »
George
Hi George,
Russ
Brilliant :-)
One step at a time!
Offline rcaffin
  •  1,073 1,073
« Reply #3 on: May 09, 2015, 02:03:42 AM »
I will assume you are going to use several passes, maybe 0.25 mm...
Evil fortune descends on he who mixes his units!
That said, you could start at 400 mm/min and see how that goes. It does depend a lot on your machine.
That totally depends on the rigidity and horsepower of your machine. That said, you should be able go up to 0.5 mm/pass without any problems, IF you are using a MILL. If it's a router ... 0.25 might be right.
That's a trick question. imho, the best cutting alloys are Fortal, 7075, 2011 and 6082, in descending order. But they cut OK. I use air-blast and the odd puff of kero/oliveoil mist for them.
The softer bending grades - 5nnn, 6060 etc, are like soggy chewing gum and are a pig. They clog the cutters - which then glow and break.
Roger
« Last Edit: May 09, 2015, 02:05:16 AM by rcaffin »
« Reply #4 on: May 09, 2015, 05:10:36 AM »
Thanks Roger, your comments are welcomed, I also love the comment "Evil fortune descends" I'll bear it in mind.   ;D it was 12.5mm thick really.
Best regards
George
« Last Edit: May 09, 2015, 05:13:19 AM by Len-Tikular »
One step at a time!
« Reply #5 on: May 09, 2015, 05:19:07 AM »
12.5 inches ???????, or 12.5mm thick.
Let's assume 12.5mm thick on possibly a 1.5hp triac, but then 2100rpm is a bit slow for a triac.
With a 10mm 3 flute slot drill you should be able to run around the plate with one cut at about 150 - 200mm/min. Slotting or pocketing will be slower at about a third of open face cutting. I would suggest a two flute slot drill to get the swarf out better, you'll sacrifice a bit of cutting feed speed but benefit with swarf removal.
6082 is your friend with this sort of job, machines well and is cheap to source.
Offline dude1
  •  1,253 1,253
« Reply #6 on: May 09, 2015, 05:28:17 AM »
you could get a 2 flut coated cutter one for aluminum and run a lot faster
« Reply #7 on: May 09, 2015, 06:17:05 AM »
It's also going to be difficult to produce a 6mm slot with the 10mm cutter ... especially 12.5" deep.
« Reply #8 on: May 09, 2015, 07:01:12 AM »
Thank you all, I suppose thats what I get for mixing inches and milli things  ;D
Here's a picture of my Mill, just to clarify. It's an Eagle25 purchased in UK. I think it is much the same as the Rong Fu 30 maybe ?
It has a 1 Horse motor.
Chuck fellows (and others) did a great job of converting their machines so I thought I would give it a try.
I'm not sure I like the Z axis conversion so I went searching and found a couple of alternative methods that I'd like to try.
I have attached a picture of my preferred route, I just hope the owner 'Pertsa' over on homemodelenginemachinist forum responds to my message.
And thanks daniel, I get myself some coated 2 flute cutters.
Regards to all
George
« Last Edit: May 09, 2015, 07:06:13 AM by Len-Tikular »
One step at a time!
« Reply #9 on: May 09, 2015, 02:18:58 PM »
If you clog up an end mill throw it in some lye ( sodium hydroxide) and it will dissolve it right off without damage to the cutter. Small machines are a bit of a problem with spindle speeds.  You really want a high speed spindle because you don't have the ridgidity to use large cutters, yet you'd like to be able to drill a good size hole, which takes torque.  My homebuilt CNC has a minimill spindle at 3800 rpm, and a router from 8000 to 35000 rpm. Its not real stiff so in aluminum the router is way better.
