Hello Guest it is November 07, 2026, 01:50:47 AM
Author Topic: DMC-2143 time out  (Read 52795 times)
Re: DMC-2143 time out
« Reply #10 on: November 07, 2015, 07:08:50 AM »
I have two core processor 3 GB RAM 512 MB Video Windows XP Professional
With version 4.5, the CPU load 0% , with version 4.6  50% when I just turned on the Mach3.
« Reply #11 on: November 08, 2015, 04:41:59 AM »
I found the document "Tormach machine controller"
which focuses on the problem of choosing a computer for Mach3.
They use the LTP port, whether it is possible to apply to the ethernet port.
They recommend using the computer on a new Intel Atom processors.
Steve what motherboard you're using?
Thank you.
Vilorijs
Offline smurph
  •  1,575 1,575
« Reply #12 on: November 16, 2015, 11:10:53 PM »
D2700-MUD Atom board.  2.1 GHz, I believe.  4GB of RAM on Windows 7 32 bit.
Steve
« Reply #13 on: November 18, 2015, 11:05:56 AM »
I bought another computer.
Intel D945GCLF2D Atom 330 1.6Ghz 2Gb RAM.
Installed Windows XP Sp3 latest drivers, GalilTools, Mach3 3.043.062.
And I try to use version 4.5 and 4.6. With version 4.6 25% CPU load with version 4.5 0%
To verify that the loads the processor, downloaded program ProcessExplorer
for it can be seen that galil.dll version 4.6 or the libraries it uses loads the processor.
And version 4.6 uses the library hal.dll, and the version 4.5 does not.
Steve what can advise?
Offline smurph
  •  1,575 1,575
« Reply #14 on: November 18, 2015, 12:09:50 PM »
The difference between 4.5 and 4.6 is the Galil communication libraries.  I don't know what may be causing the CPU load.  I simply don't see it on my machine at all.  But...  25% is not 100%, so it should run fine.
