Hello Guest it is November 01, 2026, 10:06:18 AM
Author Topic: First Problem noticed  (Read 57678 times)
hjboven
« on: March 05, 2006, 01:31:19 PM »
Thanks for putting the beta online. It reallylooks like you are filling in a missing link here. I like what you've done and it really looks promising. it tookme only minutes to get some output form an imported DXF file. Youre video tutorial is superb at getting a fast start and good help to.
I tried a sample file from autocad. A simple rectangle in wich tomill out a circle and an ellipse.
I loaded the file in mach 3 and it gave mea surprising result.Look at the screenshot of the toolpath display. Somehow the circle does not come to a good end. Just mm's before the end the tool moves back in (at the arrow).
I ran the g-code file trough CncSimulator from Microtech and it doesn't want to run as it reports "G02: illigal end point" afther the G02 X4.4268 Y6.3776 I-1.4501 J0.0000  line.
Thanks a lot for your nice work on this program and goodluck getting the bugs out.
Henk-Jan Boven
Re: First Problem noticed
« Reply #1 on: March 05, 2006, 05:12:01 PM »
Try slowing down the feedrate with the FRO. The Green line in Mach is drawing a little slow I think....
 It runs great here
Brian
www.newfangledsolutions.com
www.machsupport.com
