Hello Guest it is October 22, 2026, 01:19:56 AM
Author Topic: CSIO/IP-A WARNING  (Read 34914 times)
CSIO/IP-A WARNING
« on: May 02, 2015, 12:01:11 AM »
DO NOT BUY !!!!   I HAVE TRIED EVERY THING WITH MINE ,EVEN DIFFERENT COMPUTERS. ALL I CAN GET IS "CONECTION FAILED". I HAVE DONE EVERYTHING THE MANUAL SAYS TO DO. WHEN YOU TRY TO UPLOAD FIRMWARE IT SAYS "NO DEVICE FOUND".I EVEN HAD TO MAKE A NEW CROSS OVER CABLE ,THE ONE THEY SENT WAS WIRED WRONG(TWO WIRES CROSSED)THERE IS ALSO NO SUPPORT. DO NOT WASTE YOUR MONEY
Offline TPS
  •  2,627 2,627
Re: CSIO/IP-A WARNING
« Reply #1 on: May 02, 2015, 01:20:57 PM »
good luck, for the rest of your project.
« Reply #2 on: May 02, 2015, 02:19:28 PM »
Now that does surprise me, the CS-Lab products I have used have always been excellent and the documentation is first class.
« Reply #3 on: May 02, 2015, 03:14:30 PM »
 Like Hood  also use CS- Lab products and never had any issues, as for the service never had to wait more than a day or two for a reply
« Reply #4 on: May 02, 2015, 03:50:28 PM »
I have tried every thing i can think of,and have not received a response from cs lab. i dont mean to sound so negative but after two weeks and I still cant even communicate with the controller.im not the best at computers ,but a simple network connection should be simple. when i connect 24 volts i dont even get any lights on the front I get etherrnet leds but thats it
« Reply #5 on: May 02, 2015, 06:19:16 PM »
If you do not get any LEDs lit then something is amiss with either your power supply or the IP-A itself, you should have some LEDs showing at Stat 0-3.
« Reply #6 on: May 02, 2015, 06:36:13 PM »
I have checked my power supply , its putting out 24v. all i get is the ethernet leds flashing.
« Reply #7 on: May 02, 2015, 07:01:15 PM »
I think im going to have to send the controller back to be ckecked. I did not realize there should be leds lit.
« Reply #8 on: May 02, 2015, 07:16:21 PM »
Sounds like a problem with the IP-A then :(
I am not at the workshop (its after 1am here :( ) but I think you should see all 4 Status LEDs flashing when you apply power and Mach is not started.
Just double check that there is 24v when the power supply is connected to the IP-A, it may be your power supply is faulty and getting pulled low when there is a draw on it. It is unlikely but certainly worth checking before you have to send the IP-A back.
« Reply #9 on: May 02, 2015, 08:01:51 PM »
I already made that check (its ok). when i turn the power on i get my solid yellow and flashing greed led for the ethernet, but nothing on Stat 0-3.I do like the way this controller is set up ,If i can get it to work.
