Hello Guest it is November 22, 2026, 11:09:44 PM
Author Topic: Cancel the A axis  (Read 12156 times)
Cancel the A axis
« on: May 01, 2015, 08:22:46 PM »
Is there any way to cancel the A axis from a macro.
I need the A axis does not move when I activated his brakes.
best regards
Renato
Re: Cancel the A axis
« Reply #1 on: May 02, 2015, 10:43:21 AM »
If you do not want the A axis to move do not give it any motion commands. It will NOT move until you tell it to.
« Reply #2 on: May 02, 2015, 01:56:54 PM »
If the A Axis is moving when applying the brake then it sounds like you have a noise issue, ideally all low voltage signal wiring should be shielded and properly grounded.
« Reply #3 on: May 05, 2015, 06:53:15 PM »
Hi, My A axis work well, with insulated cables, i use the macro M40 for brake the A axis,
with ActivateSignal(Output5) brake mecanical A axis
with DeactivateSignal(Output5 ) the A axis is free.
when the A axis is brake, the operator can make the mistake of moving the axis with the keyboard, wheel or give movement commands. To avoid this i would see if there is any way to cancel the A axis for software without entering a Port and Pins every time i brake the axis A.
regards
Renato
« Reply #4 on: May 05, 2015, 07:40:33 PM »
You could maybe include a toggle of the "Axis Inhibit" for the A in your macro.
OEM Code Function 253
Russ
« Reply #5 on: May 06, 2015, 07:24:26 PM »
work as desire, A axis is canceled
Renato
« Reply #6 on: May 06, 2015, 07:35:59 PM »
Good Job Russ,  8)
