Mach Discussion => General Mach Discussion => Topic started by: Renatox_ on May 01, 2015, 09:22:46 PM
Is there any way to cancel the A axis from a macro.
I need the A axis does not move when I activated his brakes.
best regards
Renato
If you do not want the A axis to move do not give it any motion commands. It will NOT move until you tell it to.
If the A Axis is moving when applying the brake then it sounds like you have a noise issue, ideally all low voltage signal wiring should be shielded and properly grounded.
Hi, My A axis work well, with insulated cables, i use the macro M40 for brake the A axis,
with ActivateSignal(Output5) brake mecanical A axis
with DeactivateSignal(Output5 ) the A axis is free.
when the A axis is brake, the operator can make the mistake of moving the axis with the keyboard, wheel or give movement commands. To avoid this i would see if there is any way to cancel the A axis for software without entering a Port and Pins every time i brake the axis A.
regards
Renato
You could maybe include a toggle of the "Axis Inhibit" for the A in your macro.
OEM Code Function 253
Russ
work as desire, A axis is canceled
Renato
Good Job Russ, 8)
