Hello Guest it is November 17, 2026, 09:51:42 AM
Author Topic: Z Axis not moving afer loading GCode  (Read 22670 times)
« on: May 01, 2015, 01:22:40 PM »
Machine jogs properly, with arrow keys and PgUp and PgDn.  After the GCode is loaded, can't jog Z Axis with PgUp and PgDn.  The machine will run the code, but kind of hard to zero the z axis.
Anyone have any ideas.   Have been looking similar issues for a couple of days now.
Mach 3
3 axis router NO ATC
BobCad
Thanks....
Re: Z Axis not moving afer loading GCode
« Reply #1 on: May 05, 2015, 12:46:41 PM »
anyone?
Offline TPS
  •  2,627 2,627
« Reply #2 on: May 05, 2015, 01:29:46 PM »
pls post Your G-code
Thomas
« Reply #3 on: May 06, 2015, 04:28:15 AM »
I've attached a snipped of my code.  Again, there must be something I failed to check in the config file.  The code has not changed and the program runs fine. It's only when , in the middle of the program, I stop the machine and need to jog an axis that I am not able to jog it.
tony
( T1 |  1/8 FLAT ENDMILL | H1 )
( T2 |  3/16 FLAT ENDMILL | H2 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
( DRILL )
N104 T1 M6
N106 G0 G90 G54 X-2.407 Y.6902 A0. S2139 M3
N108 G43 H1 Z.1
N110 G99 G83 Z-.765 R.1 Q.06 F26.11
N112 X0. Y1.304
N114 Y-1.304
N116 G80
N118 M5
N120 G91 G28 Z0.
N122 A0.
N124 M01
( SPIRAL )
N126 T2 M6
N128 G0 G90 G54 X.1907 Y.5248 A0. S4278 M3
N130 G43 H2 Z.25
N132 Z.2
N134 G1 Z-.05 F16.16
N136 X.1456 Y.5433 F26.16
N138 X.0984 Y.5581
N140 X.0498 Y.5687
N142 X0. Y.575
N144 X-.0505 Y.577
N146 X-.1013 Y.5745
Offline TPS
  •  2,627 2,627
« Reply #4 on: May 06, 2015, 04:41:23 AM »
Hi Tony,
ok i was on the wrong road.
can you check  CONFIG -> GENERAL CONFIG -> Jog modus allways active
hope it named so, because i have a German Version.
Thomas
« Last Edit: May 06, 2015, 04:43:08 AM by TPS »
« Reply #5 on: May 12, 2015, 07:34:34 AM »
Have been going round and round on this..... ughhhhh!
When I load the roadrunner sample GCode, all works properly.  However when GCode from my BobCAD gets loaded, the Z axis will not move with the PageUp / PageDown keys.  The code runs properly, but can't zero the z axis.
Here is the header and first few lines of GCode.
(BEGIN PREDATOR NC HEADER)
(MACH_FILE=HAAS - 3XVMILL.MCH)
(MTOOL T1 S1 D.25 C0. A0. H2.5)
(SBOX X0. Y0. Z-1.5 L16. W3.5 H1.5)
(END PREDATOR NC HEADER)
O100
(PROGRAM NUMBER)
(PROGRAM NAME - COLLETRACK2.NC)
(POST -  MACH 3 MILL NO ATC)
(DATE - FRI. 05/01/2015)
(TIME - 04:29PM)
N01 G20 G40 G49 G54 G80 G90 G91.1
;N02 G53 Z0.
(Machine Setup - 1  Pocket)
(FEATURE 2 AXIS)
;N03 T1 M6
N04 S3819 M03
N05 G00 G90 G54 X1.025 Y2.75
;N06 G43 H1 Z1. M08
N07 Z.2
N08 Z.1
N09 G01 Z0. F45.8366
N10 Z-.25
N11 G17 G03 X.975 Y2.75 I-.025 J0. F91.6732
N12 X1.025 Y2.75 I.025 J0.
« Reply #6 on: May 12, 2015, 07:54:16 AM »
The BCad file loads completely ... with no errors ?
Only the Z is inhibited ? ? ?  not the x or y ?
Can you post the complete file ?
Russ
« Reply #7 on: May 12, 2015, 08:51:51 AM »
You can zero the axis before you load the code.
Might also post your XML so someone can check your configuration.
Russ
« Reply #8 on: May 12, 2015, 01:00:11 PM »
Thanks for the quick reply!
Yes, Z axis jogs just fine until the GCode is loaded, then Z can't be jogged.
X and Y axis work before and after loading GCode.
Complete GCode attached.  XML on next post
Thanks again!
« Reply #9 on: May 12, 2015, 01:04:36 PM »
and here is the XML file
