Hello
Guest
it is
November 17, 2026, 09:51:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Z Axis not moving afer loading GCode
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Z Axis not moving afer loading GCode (Read 22670 times)
Overloaded
4,923
Re: Z Axis not moving afer loading GCode
Reply #10 on:
May 12, 2015, 02:19:16 PM »
I don't see any problems with it here. R3.043.022
All appears to work well (nice rack too !).
Maybe someone else will have a look and chime in.
Russ
Logged
BR549
6,965
Reply #11 on:
May 12, 2015, 08:09:36 PM »
IS this a LPT version or an outside controller version ?
NcUsbPod-XHC-Mach3-USB-Motion-Card >>>
GUYS you really need to ASK about the controller UP front or spend time running in circles . The NCpod has been obsolete for years now and it never worked 100%.
Just a thought, (;-) TP
Logged
Overloaded
4,923
Reply #12 on:
May 13, 2015, 08:27:17 AM »
Good point TP, will keep that in mind, thanks.
btw .... where did you find "NcUsbPod-XHC-Mach3-USB-Motion-Card >>>" ? ? ?
I didn't see it in any post ... or the xml. ? ? ? ?
Russ
Logged
BR549
6,965
Reply #13 on:
May 13, 2015, 11:10:41 AM »
IT IS in the XML (;-)
</Preferences>
- <Mach3Mill>
<WPVB>680</WPVB>
<WPVT>13</WPVT>
<WPVL>219</WPVL>
<WPVR>1225</WPVR>
</Mach3Mill>
- <Control>
<Device>NcUsbPod-XHC-Mach3-USB-Motion-Card</Device>
</Control>
- <VideoPlugIn>
<DROcolor>0</DROcolor>
<TOOLcolor>8421440</TOOLcolor>
<CROSScolor>4194304</CROSScolor>
<ShowTool>1</ShowTool>
<ShowMousePos>1</ShowMousePos>
<ShowAxisPos>1</ShowAxisPos>
<ToolDia>0.5</ToolDia>
<ScaleFactor>2.e-003</ScaleFactor>
<FlipAxis>0</FlipAxis>
</VideoPlugIn>
- <Pod>
<DripSel>0</DripSel>
<GBufTime>512</GBufTime>
<FSlect>16</FSlect>
<HomeLimitEn>0</HomeLimitEn>
<Config>1</Config>
<PulsCntPeroate>2</PulsCntPeroate>
<Homing>1</Homing>
<pulseHz>4</pulseHz>
<XPullOff>5.0000</XPullOff>
<YPullOff>5.0000</YPullOff>
<ZPullOff>5.0000</ZPullOff>
<APullOff>5.0000</APullOff>
<BPullOff>5.0000</BPullOff>
<CPullOff>5.0000</CPullOff>
</Pod>
Last Edit: May 13, 2015, 11:12:54 AM by BR549
Logged
Overloaded
4,923
Reply #14 on:
May 13, 2015, 12:40:54 PM »
OK ... I see it now. Totally overlooked it,
thanks TP.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
