Hello Guest it is November 13, 2026, 09:59:09 AM
Author Topic: mach 3 licence not loading heeelp  (Read 15907 times)
« on: April 30, 2015, 02:45:49 PM »
Ive got my licence for mach 3 but i cant load it. I have the limited version installed, but it says that windows cant open this file??
any ideas
regards
alex
Offline TPS
  •  2,627 2,627
Re: mach 3 licence not loading heeelp
« Reply #1 on: May 01, 2015, 02:53:42 AM »
you only have to put your licence file into Mach3 folder, nothing else,
then run the "normal" Mach3.exe.
« Reply #2 on: May 01, 2015, 03:52:16 AM »
Thank you for your reply.
I open my email, which has the licence attached, i grab it and drop it into the mach 3 folder, but it still remains as demo?
Regards
alex
« Reply #3 on: May 01, 2015, 03:57:08 AM »
Regards
alex
sorted mucker thank you
« Reply #4 on: May 24, 2015, 02:41:03 AM »
I have this problem now.
And i have no idea what "you only have to put your licence file into Mach3 folder, nothing else,
then run the "normal" Mach3.exe. means?????
it still says DEMO!
Please someone help!!!!
Offline TPS
  •  2,627 2,627
« Reply #5 on: May 24, 2015, 02:58:34 AM »
you normaly get a file named Mach1Lic.dat witch is your licence.
copy this file in your Mach§ folder (witch is normaly C:\Mach3)
and then start Mach3 again.
Thomas
« Reply #6 on: May 24, 2015, 03:06:07 AM »
I dont understand? do I drag and drop it?
Everyone says copy it but I don't get it?
Offline TPS
  •  2,627 2,627
« Reply #7 on: May 24, 2015, 03:09:40 AM »
normaly you get your licence file in a email as attachment,
yust put ( copy or drag and drop, however you want to call it) this file
into c:\mach3 folder.
« Reply #8 on: May 24, 2015, 03:13:47 AM »
ok it finally worked when i opened it up until it said Mach1Lic and dragged that over.
Many thanks!!  You are the man!!
