Mach Discussion => General Mach Discussion => Topic started by: craftyfifer on April 30, 2015, 03:45:49 PM
Ive got my licence for mach 3 but i cant load it. I have the limited version installed, but it says that windows cant open this file??
any ideas
regards
alex
you only have to put your licence file into Mach3 folder, nothing else,
then run the "normal" Mach3.exe.
Thank you for your reply.
I open my email, which has the licence attached, i grab it and drop it into the mach 3 folder, but it still remains as demo?
Regards
alex
Regards
alex
sorted mucker thank you
I have this problem now.
And i have no idea what "you only have to put your licence file into Mach3 folder, nothing else,
then run the "normal" Mach3.exe. means?????
it still says DEMO!
Please someone help!!!!
you normaly get a file named Mach1Lic.dat witch is your licence.
copy this file in your Mach§ folder (witch is normaly C:\Mach3)
and then start Mach3 again.
Thomas
I dont understand? do I drag and drop it?
Everyone says copy it but I don't get it?
normaly you get your licence file in a email as attachment,
yust put ( copy or drag and drop, however you want to call it) this file
into c:\mach3 folder.
ok it finally worked when i opened it up until it said Mach1Lic and dragged that over.
Many thanks!! You are the man!!
